Glue remover
My problem is not removing the adhesive, when you find something that you can spray on tint and wipe the shiot off...call me :thumb
Not sure if this will work exactly like you want it to but it's close.
http://www.44tools.com/merchant2/merchant....egory_Code=chem
Spray the tint off on the window film cover as you would if you were using the bagging method for the window.
Let it sit for at least 5 minutes. After 5 minutes pick a corner and pull film off as usual. If the film is sticking and won't pull easily then reapply solution and let sit for another 5 minutes.
This solution will not get all of the adhesive off the window but will remove a lot of the adhesive and make it easier to remove the rest of the adhesive.
