What is overcoat???
Did a job today... used a MMM film. I opened the box and on the instruction sheet, it says to wash off overcoat.
What are they talking about?? I know it's probably a stupid question, but I've never heard of that before...
RoAcH
The liner? I guess.. the reason why I didn't think that was it is because on the sheet, they have a picture that shows someone washing off the overcoat. It says "Overcoat is dissolved when water is running off film".
We pulled off a liner... so it had one.
As for washing the surface... The guy I was with didn't do anything different then any other film I've used. Clean glass... wet.. apply film.. squeegee, bump.
I dunno... it looked no different when we were done.
I don't use MMM... but when I work with this other company that's what they use. So I've only used it a handfull of times and I don't really know much about it.
RoAcH
Guest darkdan
As long as you use a decent amount of water on the glass when you squeege the detach coating will come off.
I've never had to do anything different.
Of course, I use A LOT of water because I'm a n00b.
Guest vclimber
Yep, it's the DPS adheasive. Some wash it off by pulling the liner and spraying the film as well as the glass, and some just spray the glass real well.
Ah, ok. I think I get it now.. and we did spray the film as well as the glass before putting it on, so I guess it was wet enough .
The instruction sheet just made it seem like it was on the non-adheasive side, but I guess I was looking at it wrong.
RoAcH
    2. 6
      Low angle haze
    3. 6
      Low angle haze
    4. 6
      Low angle haze
    5. 6
      Low angle haze
    6. 1
    7. 6
      Low angle haze
    8. 6
      Low angle haze
    9. 6
      Low angle haze
    10. 0
      HIRING INSTALLERS - full time positions Vinyl Graphic Installers
