Best Tint to Keep Cool in Home
Guest SteveLD
Guest SteveLD
Hi all,
I'm new here and I'm looking for the best window film to put on the windows of my house to reduce the heat obtained thru the sun's rays. I want maximum cooling, while have zero to little visible tint (basically, as clear as possible). I'd prefer a do it yourself kit, but if I need to have a certain kind professionally installed - if it will make that much of a difference - then I'll do it.
I've heard good things about Huper, particularly for cars. I've also heard that some of the 3M products and Gila are good as well.
What films, would best meet my needs?
Thanks a bunch!!! :finger:
  • Replies 53
Guest Tint Centre
Steve
I install both Huper and Madico Ceramic films. They are indeed the best films if you are looking to preserve the low reflectivity of your glass. The Ceramic films also reject the uncomfortable infrared heat that you feel from direct sunlight. However if you want maximum cooling you must go with a reflective film to lower your shading co-efficient. And of course I recommend a professional install, cause you do not want to waste Ceramic films... They are expensive.
Hi all,
Thanks a bunch!!! :dunno
Guest vclimber
Ok, let's see if we can do this without naming names then... :dunno
1st you want the lightest film
2nd the maximum TSER in that catagory
3rd to be able to install it yourself
Well if you want the first two really bad, then #3 :lol
The lightest and highest heat rejector that I know of is:
78% VLT (almost clear)
46% TSER
There are some 70% VLT films (slightly darker) that can reject a little more heat but I was sticking to your 1st and 2nd wishes. Is this clear film the best tint to keep cool in the home as your topic says? :lol
Guest SteveLD
Thanks for the responses.
Now it doesn't neccessarily have to be completely clear, I just don't want a very noticeable tint. So far the Gila Platinum seems to be the best choice if I do it myself.
Is there any other brand that has better performance for heat reduction that has a similar tint to the Gila Platinum, as I don't think that it is too dark. Perhaps even one that is just a real little bit darker would be ok too.
Thanks!
