Guest SSC Posted June 8, 2006 Report Share Posted June 8, 2006 What do you do when you spray the glass and the solution just beads up? It's got to be this truck because the same bottle worked fine earlier. It's p1ss1ng me off because the tint won't slide! What do you do when you spray the glass and the solution just beads up? It's got to be this truck because the same bottle worked fine earlier. It's p1ss1ng me off because the tint won't slide! what's weird is that it isn't the whole window... just parts of it. ideas? Link to comment Share on other sites More sharing options...
TITAN500 Posted June 8, 2006 Report Share Posted June 8, 2006 I use a product Called nNo touch Glass Stripper to get that crap off. You can also add xtra slip to your spray bottle Link to comment Share on other sites More sharing options...
Protint Posted June 8, 2006 Report Share Posted June 8, 2006 I use film on for installs. When that happens to me I will add a little J&J to my bottle and that seems to work fine. Link to comment Share on other sites More sharing options...
Texastintchick Posted June 8, 2006 Report Share Posted June 8, 2006 Scrub the window with alchohol, then clean as ussual. I hate that but cleaning it with alchohol first seems to help Link to comment Share on other sites More sharing options...
Protint Posted June 8, 2006 Report Share Posted June 8, 2006 I have always wondered what caused that. I think that the window was treated with an anti-fog solution or something like that. Even though it has been cleaned I bet that stuff is still in the pores of the glass, kinda like adhesive after you strip a window. I can see how alchohol would help. Link to comment Share on other sites More sharing options...
Guest gtotint Posted June 8, 2006 Report Share Posted June 8, 2006 Scrub the window with alchohol, then clean as ussual. I hate that but cleaning it with alchohol first seems to help Link to comment Share on other sites More sharing options...
Guest cactustint Posted June 8, 2006 Report Share Posted June 8, 2006 my rep told me rubber rubing glass is what can do this Link to comment Share on other sites More sharing options...
Guest 1PEECBARETTA Posted June 8, 2006 Report Share Posted June 8, 2006 dirt off works well Link to comment Share on other sites More sharing options...
TINTZEUS Posted June 8, 2006 Report Share Posted June 8, 2006 what I do is shake my bottle or can. I have a big can if I have a bottle, add a little soap. then start movin faster Link to comment Share on other sites More sharing options...
BIG E Posted June 8, 2006 Report Share Posted June 8, 2006 Scrub the window with alchohol, then clean as ussual. I hate that but cleaning it with alchohol first seems to help I think its FogX or something and alcohol and a scrubby usually do the trick! Link to comment Share on other sites More sharing options...
