Guest ssarver Posted June 9, 2006 Report Share Posted June 9, 2006 Hi guys, was hoping you could help me out. I'm trying to tint the back glass of a 73 monte carlo. This window is quite "curved' and has a seem going right down the middle of the window. When I lay a 48' piece of tint over the window (so I can do one piece) using the dry method, there is a huge finger that goes the whole length of the window. there is no where I can "separate' it so I can shrink from either top or bottom. So I try hitting the middle of the finger with the gun, it shrinks and I end of getting creases in the tint every time. does this window need to be be done via the two piece method? I know years ago I had a monte and paid someone and I remember a line through it so they did a two piece. Any help would be appreciated. thanks scott Link to comment Share on other sites More sharing options...
TINTDESIGNZ Posted June 9, 2006 Report Share Posted June 9, 2006 Try wet shrinking it-or split it on the seam running up and down! Link to comment Share on other sites More sharing options...
Guest 1PEECBARETTA Posted June 9, 2006 Report Share Posted June 9, 2006 Try wet shrinking it-or split it on the seam running up and down! Link to comment Share on other sites More sharing options...
