proper film solution mixture
Guest SolarShopFilm
Guest SolarShopFilm
I use a 3 gallon sprayer to do residential/commercial window film. Ive recently been having problems with the solution. Can anybody suggest a better solution to mix up, or maybe a solution that has been working for you. Thanks.
Guest 1PEECBARETTA
You are probably going to experiment a little to find out what works best for you.Is it hot where you are? how big is the glass, are you a novice, and what isit speciffically are you having a problem with, slip adhesion ect.
Guest VOLTRON
yes like climber said it depends on the type of film you are using aswell as the type of adhesive on the film. If I am hanging Huper or MAC which has a PS adhesive I will use more slip because of the agressive adhesive. On water activated or dry adhesive I will use less. I have a 5 gallon tank and I just squirt until it feels like I have enough. No mathmatical process for me.
Guest 1PEECBARETTA
In the south there are 2 measuring systems
1-dollop measurement
2-sh!tload system
for liquid measurement you have to use the dollop
10 dollops per gallon should be sufficient as a base to make adjustments from
good luck
a pick-up truckload is equivalent to a sh!tload (f.y.I)
    2. 7
    3. 7
    5. 7
    6. 0
    7. 11
    8. 11
