Question about cut Glass????
Guest CSCustoms
Guest 1PEECBARETTA
You just told on yourself! That cut in the glass was so ragged that there is no way I could have done it.Besides,I've been tinting so long that I can use a carbon blade and not scratch glass.
Guest nautiboi73
:finger:
CSC I have never heard of a way to get it out.
but try cleaning the glass real well before you cut, maybe you are pulling debris or something
because it you are doing all of the above you would have to be standing on the knife to scratch the glass IMO.
Guest tintjob@yahoo
snap snap snap....... always keep a sharp blade. One thing that I try to avoid is putting my index finger at the end of the blade holder. It seems to cut down on the pressure that gets applied to the glass. Hope the info helps :finger:
:beer
:woowoo:lol "standing on the knife" :finger:
CSC I think the Eastwood company carries a kit to remove minor scratches from glass! I have never tried it, but if the scratches are not to deep it may be worth a try, they {Eastwood} are a reputable company}! :finger:
Refine your results:
By Category.
Care & Custom (131)
Styling (131)
Specialty Coatings (72)
Tools & Equipment (68)
Auto Body (49)
HotCoat Powder Coating (20)
Abrasive Blasting (19)
Metal Buffing & Finishing (16)
Rust Treatment (13)
Metal Forming (10)
Grinding & Filling (5)
Performance & Tune-Up (5)
Product Groups (5)
Hammers and Dollies (4)
Painting and Pinstriping (3)
more By Sub Category.
Plastic & Glass Repair (74)
Shop Equipment (42)
Detail Coatings (34)
Interior (34)
Shop Tools (26)
Painting (25)
Body & Fender (20)
Car Care & Protection (17)
Interior Coatings (16)
Panel Repair & Prep (16)
Abrasive Blasting (12)
Rust Removal (12)
Blast Cabinets (9)
Metal Prep (9)
Powder Coating Equipment (9)
Protective Gear (8)
Welding (6)
Mallets (5)
Other Ways to Shop (5)
Styling (5)
Blasters (4)
Media (4)
Pinstriping / Airbrushing (3)
Books and Videos (2)
Brakes & Suspension (2)
Replacement Parts (2)
Surface Conditioning (2)
Underhood Coatings (2)
Drivetrain (1)
Electrical & Diagnostic (1)
Engine (1)
Hammers (1)
House of Kolor (1)
House of Kolor Paint (1)
more By Product Type:
Floor Coatings (35)
Plastic Welding (21)
Windshield Repair (21)
Interior (17)
Miscellaneous Coatings (16)
Paint Prep / Touch Up (16)
Cleaning & Polishing (15)
Vinyl Repair (15)
Abrasive Blasting (9)
Cleaning & Stripping (8)
Media (8)
Unique Tools (8)
Blast Cabinets (7)
Clean Up & Maintenance (7)
Body & Fender Tools (6)
Body Tools & Accessories (6)
Booths (6)
Headlight / Taillight Repair (6)
Clearance (5)
Glass Sealants & Cleaners (5)
Goggles (5)
Mechanical Stripper (5)
Sanding (5)
Panel Prep Tools & Accessories (4)
Welding Tools and Accessories (4)
Body Hammers (3)
Books & Videos (3)
Custom Interior (3)
Dent Repair Kits (3)
Fillers & Seam Sealers (3)
Mechanical Rust Removal (3)
Metal Working Tools (3)
Powder Coating Accessories (3)
Trim Tools (3)
Ventilation (3)
Blasters (2)
Breathing Apparatus (2)
Gas Tank Sealers & Fuel Systems (2)
General Hand Tools (2)
Interior Trim Tools (2)
Metal Fillers (2)
Specialty Products (2)
Suspension Tools & Accessories (2)
Chemicals & Additives (1)
Conditioning Kits (1)
Custom Exterior (1)
Diagnostic Testers (1)
Engine Tools (1)
House of Kolor Paints (1)
Paint Prep (1)
Pinstriping Wheels & Accessories (1)
Sound Proofing (1)
Surface Protection (1)
Trim Painting / Touch Up (1)
Welders (1)
Welding Helmets (1)
more
There were no documents that contained all of the words in your query. These results contain some of the words.
1 - 10 of 325 Search Results for glass renewal
Sort By: Popularity | Price ascending | Price descending
Glass-LITE Gallon
GLASS-LITE? is a unique reinforced, lightweight filler which offers all of the benefits of typical short strand fiber reinforced fillers. Extremely easy sanding and easy spreading. Apply to bare steel, galvanized steel, aluminum, fiberglass, SMC, plaster, concrete, masonry and wood. Ideal for non-structural ... $39.99
Item No. 31334 ZP
Related Searches: fiberglass | fiber glass | bondo | fiberglass repair
Glass Polishing Wheel Jamnut 5/8"-11 Thread
Glass Polishing Wheel Jamnut 5/8"-11 Thread $0.25
Item No. 40011 F1
Related Searches: glass polish
This Glass Polishing Wheel is used with the Pro Glass Polishing Compound (40011B) to remove the windshield wiper haze typical of older vehicles. Not for the removal of deeper scratches. Try this simple test: Run your fingernail over the damaged area on the windshield. If your nail does not get caught ... $24.99
Item No. 40011 A
Related Searches: cerium oxide | 40011b | window polish | scratch repair
One pound Glass Compound is enough to recondition several windshields. Use with Glass Polishing Wheel (40011 A) . First mark the damaged area, mix the Glass Polishing Compound with water, attach the Glass Polishing Buff to your drill or low-speed polisher (1500 rpm), dab on the Compound and keep the ... $14.99
Item No. 40011 B
Related Searches: glass polish | windshield | glass | scratched glass
Glass Polishing Kit Pro
... . If nail doesn't catch this kit will work. If your nail does catch try the Deep Scratch Kit (40030) . Mark the damaged area mix the special Glass Polishing Compound with water, attach polishing buff to your drill or low speed polisher (1,500 rpm), and start polishing! Includes: 1/4 adapter, 1 lb Glass ... $34.99
Item No. 40011
Glass Polishing Kit For Deep Scratches
Remove Deep Scratches From Glass - Now you can recondition deeply scratched automotive glass and save the replacement costs. This abrasive system literally grinds away imperfections until scratches disappear. Works with your 4 1/2" or 5" air angle grinder set at 2000 rpm. WARNING: This System ... $45.99
Item No. 40030
Related Searches: glass polish | glass | glass repair | polisher
Glass Master - Complete Unit
The Easy Way to Clean Windshields - Thorough glass detailing is now much easier! Triangular paddle system with 14" offset extension handle easily reaches into corners. Includes 2 triangular sponge faced paddles, and 3 reversible cleaning bonnets (one each: microfiber, cotton terry and nylon mesh ... $19.99
Item No. 52243
Related Searches: glass cleaning | windshield cleaner
Diamondite Glass Cleaning System
Smooth as Glass? Maybe not. Even new glass has some surface roughness - older windshields, damaged by road debris and acid rain are rougher still. See how clean your glass can be with this 3-step aerosol Diamondite System. Glass and Surface Cleaner (40060Z) reaches trapped debris that regular cleaners ... $29.99
Item No. 40057 Z
Related Searches: glass | glass polish | glass cleaner | glass cleaning
Sprayway Glass Cleaner 19 oz
Detailing to Perfection? Then you won't want to be without Sprayway Glass Cleaner. This versitile foaming cleaner quickly removes oil films that can lead to wiper streaking. 19 oz. net wt. aerosol can. $4.99
Item No. 40150 Z
Related Searches: glass cleaner
Spot Blaster Abrasive 3lb Glass Bead
Glass Bead Media is great for removing paint and carbon. One year hassle free warranty. $4.99
Item No. 22063
Related Searches: glass bead | blast | glass buffing
Page 1 2 3 4 5 6 7 8 9 10 11>> of 33 | Next
Copyright 1999-2006 SLI Systems, Inc. All rights reserved.
Did you find this search useful? Yes | No
Home | Site Map | About Us | Find Us at a Car Show | Customer Testimonials | Customer Service
Privacy & Security | Terms & Conditions | Useful Links | Affiliate Program | Partners ?2006 Eastwood Co.
I am mostly computer illerate but I tried to underline the glass kits! :finger:
one shop I work at is a glass shop and they do polish out scratches, but if you can feel it with a finger nail then it is pretty well over.
for keeping it from happening then only thing I know will always work is the button technique. Use a button under the knife blade and it will slide along keeping the film cut and the blade from the glass.
otherwise dirt or cheap glass is usually the culprit if you have a stainless fresh and well snapped blade.....
Guest Shady
I have heard that jewlers rouge and a high speed buffing wheel works, but I've neer seen it done. :lol6
I've used that jewlers rouge when I was a windscreen fitter. Its a powder I watered down and buffed with a small electric head designed for the job. It was OK on very, very light scratches but its pretty useless, I found, for anything that may warrent it.
In future use a small piece of card between the glass and the blade :hump
Guest nautiboi73
also you can take the time to get a cutting talbe. or cuting wall.
I only do one cut on most SIde's and thats the top, I use a china maker (or sharpe)and ruler for the edges and bottom and I promise my cuts come out better, less fingers when installed and just overall a better install for me vs, cutting on the car.
something to consider.
    2. 7
    6. 11
    7. 11
