407 sedan?
Guest nightly_tinting86
Trims can be peeled back at the top to expose the rubber strip which can be carefully pulled out. I took the rear trims off totally there were hex screws behind the woodgrain door pull panel,X2, 1 hidden below the handle by the map pocket area and two up the side of the trim. It makes it nice and easy to pop that rubber strip out. Be carefull removing and replacing the rear trims as they have airbags in them. The front need to remove that one hex screw on the side of the trim before you peel it back.
:krazy
    2. 7
    6. 11
    7. 11
