Anyone have pics with vynil over the dot matrix?
Guest scottstinting
I use a product called Pro bond .it seems to work really well and it makes it stick like crazy.
Alot of times it dosent even look white but it does smell real bad ,about give you a buzz
  • Replies 59
Guest 1PEECBARETTA
If you wanted to be polite you wouldn't have had to make a point to disagree with me and just posted your pics.And yes the vinyl does look crappy up close.Dan when you come to visit I'll show you how a real window tinter lays film on the dots and makes it look good.
Guest 1PEECBARETTA
Vinyl is a crutch for those that can't get it right. They use it to hide creases,to lessen the amout of area they have to shrink, things like that. There are plenty of threads around here to help you deal with the matrix area. Look around and try some out, it will make your work alot better, and ultimately satisfy your customers.
Guest Soultinter
It's true that with proper prep you can make the matrix stick nicely on most cars, even cavaliers. I use a red scuff pad agressively, then razor then flush, and after tint is on flush w straight water, not solution, squeege out w yellow or red turbo, looks great.
    2. 7
    6. 11
    7. 11
