Tinting in high condensation areas
Guest walestint
Guest walestint
Hi folks
Anyone know of any possible problems with condensation in swimming pool area for tint (not in the pool before anyone starts!) on the glass?
just a question from possible customer
many cheers in anticipation :)
Guest filmpeople
We have recently done 6 poolside applications at different YMCA's and a several other fitness clubs.
Never had a problem.
Condensation is not your issue. It's the kids who stick their fingers behind the film to peel it. :wall
It makes for a good return job though. :wall
Guest darkdan
I'd be best to use a water activated adhensive film instead of pressure sensitive.
The heat and extreme humidity aren't good on PS films.
Well I'm at odds with you guys.
I'd use nothing but PS because as you can observe in this photo of a swimming pool room I had to do, the glass was dripping wet.
Add to that the chemicals had made all the bottoms of the windows green where the moisture collected. :lol2
That's my handiwork on the glass emphasising the amount of moisture in the room and the need for certain films.
It's been on for about 4 years now and not a problem but I did make sure that my glazier followed in behind a few days later to put a very heavy silicone seal all around it....it's called insurance!
Devil
Guest walestint
Hi folks
many cheers in anticipation :lol2
thanks for that folks, I knew it was better to post on here rather than call my distributor!
Guest Dudtinter
Add to that the chemicals had made all the bottoms of the windows green where the moisture collected. :thumb
Devil
I agree with dry adhesive film and a silicone bead to seal edges.
PS :wall Film allows moisture out at install so certainly would allow it in reverse.
