Guest VaTinterPMan Posted July 15, 2006 Report Share Posted July 15, 2006 I have one to do tommorow and I dont know how to get the doors off for sure I can kinda do it slowly but I would rather hear it first hand before jumping in to it. So any help please thanks. Link to comment Share on other sites More sharing options...
Guest 1PEECBARETTA Posted July 15, 2006 Report Share Posted July 15, 2006 There's a few screws and some clips and stuff. Link to comment Share on other sites More sharing options...
big money Posted July 15, 2006 Report Share Posted July 15, 2006 Hopefully the list below is right, with me you never know. 1. remove the screw and box @ the pull handle. 2. remove screw and inside cover. 3. remove that tweeter panel on front doors 4. pull clips loose on perimeter of door panel 5. then either disconnect the power window switch and switch panel, if equipped w/power windows. that should get you there, hope I helped. Link to comment Share on other sites More sharing options...
Guest VaTinterPMan Posted July 15, 2006 Report Share Posted July 15, 2006 Hopefully the list below is right, with me you never know.1. remove the screw and box @ the pull handle. 2. remove screw and inside cover. 3. remove that tweeter panel on front doors 4. pull clips loose on perimeter of door panel 5. then either disconnect the power window switch and switch panel, if equipped w/power windows. that should get you there, hope I helped. My customer was wrong it was a o4 not a 03 so its the newest body style so help me with those door panels please The gasket is so tight I got the back doors are already but I cant get the front. Link to comment Share on other sites More sharing options...
