If you are a window tinter that lives near Kansas City
My summa plotter wont connect to my computer even tho i have all plugs plugged in
I sometimes have problems with my plotter not cutting or even my program not detecting my plotter. When this happens, I go to system, device manager, Ports (Com & LPT) You should be able to see your plotter listed and the Com port it is associated with. Make sure your cutting program is pointing to the same device and Com port in the program's setup area. I usually end up sorting things out eventually. Other than this, I have no other advice as I'm just a novice computer tech 😬 -
Im having a lot of trouble with conecting my summa plotter to my laptop. I have multiple plugs going from my plotter to my laptop and everytime i open a sofware for ppf and tint templates it says no plotter detected even tho the software is telling me that is has cut the templates but the plotter didnt cut. If anyone could help that would amazing, ive been stuck on this for over 2 weeks and i cant find anything online -
Problems conecting my summa T1400 SL to my laptop
Windshield protective Film
Me too. Contact me for the address to send samples to. tinttech@optusnet.com.au -
Flat Glass Installer Pay
Mutoh cutter
I live in a second story apartment and there are two windows in my living room, one facing east and one facing north. My TV is against the wall facing left and my couch is against the north wall right next to the window. In the late morning and early afternoon the sun shines through the east window and casts an annoying reflection on my TV, and sometime around 1 or 2 pm every day the sun gets right in my eyes when I am sittin or lying on my couch even when I am facing the TV. I want to cover these windows with just the right film for solving all of these problems while also making it not look obvious that I tinted them, and I'm not sure what kind I should use because apparently different brands will have different results even if it's the same percentage, could someone help me out here
