BG focus estate
Guest mototech
Guest mototech
Hi fellas im having trouble shrinking the back glass tint on my focus estate after a few attempts the film just doesnt seem to want to shrink ive used the wet method as mentioned on tintdude.com do you think this could be because im using a DIY Film I,e solar? any advice would be gratefully recieved.
cheers
marc
Guest mototech
simple one peice like it says in your other thread
just take your time and keep pluggin
you might try mdogs soap method :lol6
So what your saying is that it should work with prity much any diy film? or is it worth me getting hold of sum llumar?
cheers
marc
Guest willie
cheers
marc
it should unless your model over there is totally different than our model
the focus over here barely requires any shrinking at all :lol6
Guest walestint
cheers
marc
mmm ... something is going wrong here I think, have you shrunk rear glasses before? try the soap method if you know it from this forum
take your time (obvious) and just keep plugging away
good luck! :lol6
cheers
marc
if ya cant get it with junk dyed film, theres no need to waste the money on a roll of good film just to keep messing up ... start with low end film and practice practice practice ... nobody gets it on the first try ... well, maybe some could on a fosuc ... :lol6
Guest mototech
Hi fellas
cheers for all the replies I was using the wet method I,e spraying the rear glass with soapywater mix and laying the rough cut fil on the outside putting in a horizontal anchor with my sqeegy then going to work with the heat gun on the fingers and smoothing them out I just didnt seem to shrink at all. Il just keep pluggin away at it and see what happens.
thanks
marc
Guest solarspot
Hi fellas
thanks
marc
TRY THE SOAP!
you'll love it and never go back :beer:beer
Guest k-tintz
thanks
marc
maybe the heat gun isn't hot enough?
the gun I use ranges from 60degrees to 600degrees. I use mine on the highest setting, then I adjust how close I get to it to get the perfect amount of heat.
      3M ceramic ir vs. LLumar Pinnacle
    2. 1
      XPEL WINDOW TINT shrinking
    4. 10,324
      The Off Topic Thread
      Now Hiring experienced Tinters and Wrap Techs In the heart of Atlanta.
    6. 1
      IR Specs
    7. 1
      IR Specs
    8. 10,324
    9. 10,324
