air conditioner
Guest olletsoc
not sure. but what ever you get make sure it is oversized for the area you need cooled. going with manufacturers recomendation for square footage will leave you dissappointed
Guest solarspot
Depends on alot of factors need more info I did HVAC for 15 yrs :beer
Whats a set-up like that usually run?
OK this is gonna get complicated
What do you expect out of it do you want to be 70 when its 105
how much insulation you have most times none
do you want a package unit or split unit (like a house)
do you have the electrical available (space in your panel)
for heat, gas or electric or heat pump? or no heat
:gay I just called a local installer and they said a lil over 2k for w/e I needed. I was confused after she started rattling off a bunch of crap.
Guest solarspot
Depends on alot of factors need more info I did HVAC for 15 yrs :gay
:lol I just called a local installer and they said a lil over 2k for w/e I needed. I was confused after she started rattling off a bunch of crap.
2K sounds like a 2ton unit good luck! Make sure you get better filtration than the factory provides or you will be sorry :beer
Yea, it was a 2ton. thanx guys!
Guest solarspot
Depends on alot of factors need more info I did HVAC for 15 yrs :lol
:beer I just called a local installer and they said a lil over 2k for w/e I needed. I was confused after she started rattling off a bunch of crap.
2K sounds like a 2ton unit good luck! Make sure you get better filtration than the factory provides or you will be sorry :gay
I would go bigger or you will not be happy!
Think about it when you pull a black truck that has been sitting in the sun your shop will heat up pretty quick and by the time a 2 ton starts to catch up your done
I would go with a 3 ton min. IMO :lol
I would go with a 3 ton min. IMO :hmmm
:lol Especially with the loss due to the door being opened to cycle vehicles, its needs to be large enough to recover quickly, or like everyone else said, you wont be happy.
      3M ceramic ir vs. LLumar Pinnacle
    2. 1
      XPEL WINDOW TINT shrinking
    4. 10,324
      The Off Topic Thread
      Now Hiring experienced Tinters and Wrap Techs In the heart of Atlanta.
    6. 1
      IR Specs
    7. 1
      IR Specs
    8. 10,324
    9. 10,324
