sign writing
Guest NokTint
Guest NokTint
seen my mate put some vinyl on his backglass. his phone number about 800mm x 100mm in size. it went on all good but there were a couple of little bubbles here and there, no biggie. im guessin thats pretty normal.
ok, he peeld the entire liner off then stuck the sticker to the window. he sqeegys the entire backing sheet to give an anchor. then starting from the side hes peeling from, he squeegys out each number individually then slowly peels. is this about right ???
can I get some tips and pointers as I am going to attempt to do my back window .. im gonna use my gold card.
cheers
Guest 1PEECBARETTA
that souns about right. or , take a spray bottle, fill with water, and add about a teaspoon of dish soap.shake well. spray the window, and spray the lettering after you peel the backing. line it up where you want it, and sqweegy the excess water solution out. let sit in the sun for an hour or so to dry. then peel the mask off. good luck.
Guest scottstinting
The Best thing to use is rapid tac 2 on glass you might get by with the soap or you could use rubbing alchol mixed 50/50 with water and a couple drop of soap also
      The Off Topic Thread
    2. 12
      Tint shop owner please reply
      Would you please suggest an IR/Solar REFLECTIVE tint for my Mitsubishi Outlander panoramic roof?
      How to shrink film on windshield?
    5. 12
    6. 12
    7. 12
