How do you get clean corner cuts?
Guest johnny1
Guest vclimber
Most corners are recessed so you have to make a relief cut to get the film to lay in the corner without crimping. Then it's just a horizontal cut and a vertical one. :evilgrin
Guest johnny1
thanks dude
four quick pics
try to land two side (less cutting)
Cut a 'Dog Leg" (what the guy how showed me called it) :evilgrin
then using guide (or just your knife) cut one side Vert one side Horz
you should be able to push the tint in without creasing it
you should be able to get a nice point 90 degree point
Guest johnny1
not getting it...so the "dogleg" cut allows the bunched up corner to lay flat allowing olfa access to 90 egree cut the corner?
I think I got It.....Thanks
I never do it that way because if you cut the dogleg a little short you've trashed the sheet.
I prefer to cut down and across in little stages to eliminate the bunching into the corner.
devil
This is also the way I do it, however Johnnytint's explanation is a good way as well ( I just learned the other way first is all) Excellent pics and description Johnnytint :beer
Guest VOLTRON
I use my 5 way to and get perfect 90 degree cuts every time. I take the film and push it in with my finger but the part that I push is lower then the corner of the glass so I dont get any creases.
    rewiredtech.io
      facebook advertising for residential tint
      I would like to get feedback from the installer about the DUB film
      IWFA Membership
    4. 1
      Ineos fender
    5. 1
      Ineos fender
    6. 3
      Johnson Window Films - Palisade. Anyone have experience with this film?
    7. 0
      Model 3 rear glass
    8. 3
    9. 3
