94 Civic Rear Window
Guest iceman7329
You can use a clipboard or a binder cover as a squeege also for behind the brakelight.. I used those for years before somebody ACTUALLY came out with a tool that would work.
ON a 94 I think if you pop the trunk there are a couple bolts that hold it on, just remove those and push down on the carpet around the brakelight and manuver it out :shock
I might be wrong but give that a try, I forget what year they went to the light that is molded in with the plastic deck.
Guest 1PEECBARETTA
okay, here's the run down. the studs on the brakelight are too long to get past the deck. so push down on the deck real hard to get the studs past it.
      The Off Topic Thread
    2. 12
      Tint shop owner please reply
      Would you please suggest an IR/Solar REFLECTIVE tint for my Mitsubishi Outlander panoramic roof?
      How to shrink film on windshield?
    5. 12
    6. 12
    7. 12
