2006 XK Coupe
Guest Rockabilly
Guest Rockabilly
Door trims dont need to be removed. There is a plastic end cap on the door trim which pops off to reveal a screw. Take out this screw, and the top of the door panel can be pulled away from the door, and the rubber gasket comes out easy.
The little quarter glass windows look harder than they really are, the rubber is soft and you can slide the tint in behind it for a clean looking install. Tried to remove the rubber totally, and even asked the Jag techs what we should do, but we tried it as-is and got a good result regardless.
Rear window is a hatchback.
Guest naughtydog
I did one today amd messed around leaving the panels on - what a pain to do, the 2nd scraper on the rub rail keeps flicking the film off.
I ran out of time today so will redo tomorrow.
      The Off Topic Thread
    2. 12
      Tint shop owner please reply
      Would you please suggest an IR/Solar REFLECTIVE tint for my Mitsubishi Outlander panoramic roof?
      How to shrink film on windshield?
    5. 12
    6. 12
    7. 12
