Laminated front doors
Guest Page's
  • Replies 26
Guest SaoSA Laminating Resin
Apart from PVB, the UV-cured resin can also be used to make laminated glass. The advantages are as below,
Top quality with lower price ( just 30%-50% of other resin's cost. Help you cut the current cost 30-50% off) .
SaoSA UV curing resin is exclusively for glass lamination, which is mostly used in laminated glass, safety glass and bullet-proof glass. By choosing SaoSA Glass Lamination Resin for your glass lamination, you are able to enjoy many benefits and advantages of our good quality,
High clarity and light transmission rate (more than 91%, 4mm / 1mm / 4mm)
No yellow with ages
No De-lamination
No air bubble
Ready-to-use (one-component resin, low viscosity, easy to pour into the space between the glass sheets )
Curing quickly with UV exposure
Excellent impact strength resistance
Excellent anti-moisture capacity
Long Shelf Time (up to 18 months)
Categories:
SaoSA UV-S: Glass Lamination Resin for general architectural laminated glass.
SaoSA UV-B: Glass Lamination Resin for for bulletproof glass.
SaoSA UV-H: Glass Lamination Resin for hurricane resistent glass.
SaoSA UV-A: Glass Lamination Resin for laminated and acoustic glass
Benefits and advantages of SaoSA Resin:
1. Good Quality
SaoSA UV Cured Resin has passed the tests for various standards. We test the laminated glass made of SaoSA UV curing resin according to EN356,EN1063,EN1288-3, DIN 12600, EN12543-4(Durability testing), the testing result are very good, the testing certificates can be sent to you for your reference as requested.
The testing reports and certification were issued by TNO of Netherlands, one of most authoritative testing organizations in glass construction industry of Europe. As the matter of fact, few of resin can pass all of the above strict testing, even the resin from Europe or USA. Also, our product is the unique adhesive adopted by China Weapon Industry for using bullet-proof glass.
2. Easy to Use
Our UV curing adhesive is liquid, comprising one-component, ready-to-use casting resins for glass lamination. Our resin is Glass-like transmittance, not yellow with age and in excellent safety and security against high impact strength.
As the resin is liquid during the dosing and dispensing stage it perfectly fills the space between the glass sheets, whether these are of an irregular surface (such as tempered, toughened or hardened glass) or whether they are formed or curved glass shapes.
Curing is by UV (ultraviolet) light or strong Sun's rays, which just requires about ten minutes in exposing to UV for completion of curing. The material contains no solvents or plasticizers and no water has to be evaporated.
3. Lower Prices
The price of our resin is extremely low, helping you and your customer cut your current cost 50% off. Moreover, compared to PVB which is frequently used in processing laminated glass, no autoclaves nor heavy presses is required in using our adhesive. Moreover, low investment costs and low energy consumption are involved during production
Contact: victor@uvxm.com
Guest willie
No yellow with ages
No De-lamination
No air bubble
Categories:
1. Good Quality
2. Easy to Use
3. Lower Prices
:evilgrin
Guest Crackz
cant wait t see those windows down the line to see if there gonna have problems like the benz glass some of the older benzs look like crap with all the issuse of the lami glass with them delaminating :evilgrin
Guest Razzaq
Hi, This post of yours is very beneficial and informative, however there are some specific facts or information that I require. If anyone can help me in this matter then please send me a private message.
Best Regards,
[edit]
