CUSTOM SPEAKER BOXES
Guest afterhours
Guest afterhours
anyone into building custom car stereo boxes? no one in this area does it and I was thinking about adding that along with your general car stereo stuff. anyhow I was just wondering if anyone knew of a web site or had any info on the PROPER way to build and calculate for air space... thanks!
Guest a1wintinter
Custom boxes are not something to just jump into, but you can buy some programs to help caculate airspace.
Pretty easy once you do a little hpmework, every box is different.
Guest nautiboi73
there are alot of things to consider when making a custom box.
braces, and port size, port lenght, fiberglass? particleboard? quality of each? blah blah blah.
it is not just a six sided box with holes.
Over the years I tried messing around and making fiberglass boxes. All I can say is it isnt as easy as it looks. I used to own a cutom 97 Mitsu Eclipse and tried several times to do some custom fiberglasing for it and it always ended up a failure..lol Fiberglass sucks to work with and sanding UGH!!!!! Anyways good luck!
Guest kflemin9
my best box volume calculations were done with simple geometry equations from HS
L x W x H = volume (internal & external)
L x W x H = volume / 2 = right angle wedge volume
.. and so on
      3M ceramic ir vs. LLumar Pinnacle
    2. 1
      XPEL WINDOW TINT shrinking
    4. 10,324
      The Off Topic Thread
      Now Hiring experienced Tinters and Wrap Techs In the heart of Atlanta.
    6. 1
      IR Specs
    7. 1
      IR Specs
    8. 10,324
    9. 10,324
