mmm dealers
Guest darkdan
Talk them out of it. IIRC 3M's low-e film has a shorter warranty period than regular film.
And chances are if they're losing that much heat through the window it's from a draft and not just going through the glass.
Sell them a good solar control film and the summer energy savings will help offset the winter heating.
Also IIRC, the numbers for windows (heat gain, u-value, etc) are not for just the window, but also the framing system. Keep that in mind.
Guest vclimber
True Dan but there is much more to this story... The custmer wants low E film because they were supposed to have low E glass installed. Contractor is trying to cover his tail by using low E film to do the job instead of replace the glass...
Guest Tintin' Magician
Makes me scared to build a home, contractors today seem to only use your requests as a guideline and not the gospel. If I'm payin' for a custom built home, I want what I want, not what you think you can get away with.
Guest darkdan
Once again, if he explains the benefits of regular film over the super shiny low-e film and get the customer off of having their heart set on something with the word "low-e" in it then everyone wins.
Customers gets a good performing solar control film.
Contractor saves his rear end.
I'm guessing in SC the low-e windows there are aimed at SGH reduction and not trying to keep in the warmth. So a regular film would fit the "low-e"ness of that area.....does that make the least bit of sense?
I agree it makes since, but this guy is a military yank, no offense, who is a real detail nut. I guess where he's from, low-e is the best for glass in all climate conditions. Our climate is warm 3/4 of the year, so a good solar control film would be better. Man, my a/c is on right now a week from Christmas. :rollin:rollin
Guest vclimber
The problem a lot of times is that people think low E is giving them solar heat gain control but unless it is low E2 then they are only getting glass that is designed to keep heat in.
