97 LEXUS LS 400
Guest TATIA
Guest VaTinterPMan
Havn't Done one but I know what you talking about. The rear roll down goes down kinda funcky. But just try the seals on that yr I think that might come out if not there will be lots of screws or bolts cause its like a toyota. Rear window looks easier. not to tall. Thick defs.?
Guest tintguy7
panels should come off, not to hard to remove, just gotta find the screws, need to clean then flush the rear rollup gasket on the side that pulls away, the rear w/s just goota watch out for blistering on the rear defrosters.thats all. :thumb
Guest CloudWalker
Is the 97 LS 400 the same as the 91? I have a 91 to do Wed... Wouldn't you say using 1000 grit sandpaper on those defroster lines before install would do the trick?? :thumb
