Liking the detailplus.com tools
If you use spray bottles this is the final answer to spray heads that break, are hard to use and time consuming to pump. This new German-engineered Sprayer Head has a built-in rechargeable battery. All you do is screw it on to any spray bottle, adjust the tip for the spray pattern you want and pull the trigger. You can spray from a "0" degree to a fine mist. Will work with all chemicals except some acids.
Guest Tintbds
:sign:sign cool
Get two so one is always charged. The fine mist is it produces is excellent. Another good thing is, sorry I have to say that out of experience, it usually brakes within the warranty time so u get a new one if you have a good supplier.
Kohler, what is it that breaks on those?
THE COMPANY THAT WE HAD MAKE THEM FOR US HAS GONE OUT OF BUSINESS.
I WILL REMIND THE WEBMASTER TO REMOVE THOSE ITEMS FROM OUR WEBPAGE.
I APOLOGIZE FOR THE INCONVENIENCE.
Must be some of that Koreon stuff your so fond of, or I was just assuming thats where its made. ASSUMING being the key word here :rollin
