help installing the dei bypass module
Guest me927
I am trying to install a boa remote start system on my wifes truck and I cant figure out how to hook up the bypass module it is the dei 555L..I dont under stand how it is suppose to wire in can anyone help me by the way the truck I am working on is a 2000 chevy silverado :beer
Guest haroldshouseoftint
here is all of your wires needed for your truck,as far as the 555l goes, you have passlock II system on your truck, just follow the directions for passlock II in the instructions :beer
12volts red + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Accessory orange + ignition harness
Power Lock lt. blue + brown plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Power Unlock white + brown plug at BCM
Lock Motor gray driver kick panel
Unlock Motor tan driver kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal?
Reverse Light
Door Trigger - BCM
Notes: Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt. green - driver kick panel
Notes: Also found in the purple plug of the BCM.
Disarm No Unlock
Tachometer white ac ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Wait to start dk. blue - instrument cluster
Notes: See DirectFax document 1090.
Brake Wire white + brake pedal switch
Parking Brake
Horn Trigger black - brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
yes on the tach wire, won't run without being able to sense that the engine is running,
cut the yellow wire and the passlock system, and connect the yellow/ yellow black as in the instructions, and the black just ties in
I need help locating the tach wire it says it is white but there is a bunch of white wires in the harness going into the ecm is there anyway to get the plastic piece off where the plug bolts to the ecm or is there anyway I can wire the wire to something else
wow dude you know your chiatt :hmmm
      Customer providing the tint
    2. 1
      Tablet software
      Tablet software
    4. 1
    5. 6
    6. 1
    7. 6
    8. 6
    9. 28
    10. 6
