help installing the dei bypass module
Guest me927
ok it is the plug with a bunch of wires in it with one bolt in the center of it how do I get the bolt out or the plast cover off so I can acess the wires
he's gone for a couple of days for Christmas maybe someone else knows :ohcrap
Guest haroldshouseoftint
you should just be able to unscrew the bolt, should be a 7mm or 9/32 bolt, it will not come all the way out (the bolt) and the harness can be pulled out, but you should not need to do all that, if you can see the bolt, then you can see the wires coming out of the end of the plug, open up the loom and find the white wire that goes into the pin # associated with your engine :thumb
    2. 6
    4. 6
    6. 11
    7. 11
