compound curve
Guest tman
I HAVE HEAT SHRUNK A FEW CARS WITH THE DRYER SHEET METHOD. I GOT A 07 MAZDA 6 TO DO AND I HAVE TRIED THE DRYER SHEETS AND CANT SEEM TO GET IT TO WORK SO I TRIED THE BABY POWDER BUT WITH NO LUCK IT WONT LAY FLAT WHEN I TRY TO SMOOTH IT DOWN. NEED HELP THANKS
you don't need it to lay flat on the outside, you need it to lay flat on the inside. As long as you shrink it completely, all the little wrinkles and whatever won't matter. If you are worried, shrink it with the baby powder, then wet the outside of the back window and lay it down and squeegee it out, that will tell you how it will look on the inside.
    2. 2
      Mutoh cutter
    4. 2
    5. 1
    6. 4
