Which system is better TintTek or Computer Cut
Guest tintmasterinc
Guest sendjoshg
I agree that tinttek has one up on the others. as far as needing a 24" roll to cut side windows I will say that on a few cars this is true if the windows are right at 19", but for the most part that is not the case at all. you should use a 40" roll which will leave you with an inch on each side when you cut both door patterns out together. if you should need the 20" roll it will be when you mess up a pattern and need to redo it or if someone comes in for a one window job. in that case you can refer to tinting 101 and hand cut it. have fun.
    2. 7
    6. 11
    7. 11
