02 Acura RSX
TintWizard
Never done one ...dots matrix? panels issues ? plastic gaskets? laminate glass? Hate quoting without some insight and seeing the car, something else to worry about thanks :thumb
Guest haroldshouseoftint
heres a pic of the back end of one, pretty easy there is matrix @ the top if I recall its not as bad as the integra.
as for felt :thumb I think your ok on that no add ons have not seen laminated glass on those either :thumb
just like integras, but not as big a patch.
Instead of a 6-7" patch, the rsx is only about a 3 1/2 - 4 " patch if I recall its been a while since I've done one :thumb :thumb
Since you did the car, could you give US some tips now. I got one to do this weekend its a 2000, Thanks :)
You'll have to pull the plastic moldings on the sides of the bg. Use fine grit sandpaper on the dot matrix. Pretty much standard practice.
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
