going from dryer sheet to powder
Guest Rubes
Guest Rubes
I have this problem when I shrink a relativly flat back glass with powder it seems to over shrink
When I try to wet check it it has like a smiley on it and it creases when I try to squigee it out any help would be great
So do you start hrinking it from the bottom or the middle by the anchor :dunno
Guest thatsnappyguy
when powder shrinking, even though the film is shrank completely, the film wants to jump off the glass. this is when most ppl apply more heat to make it stay down. this is how u " over shrink." I wet shrink 99% of of rear glasses all the way to the grand prix in one piece. when I do need to dry shrink, I grab the dryer sheet. the sheet method much like the soap method lets the film lay completely down on the glass with out jumping back up.
WILL THAT STOP MY PROBLEM WITH THE OVER SHRINKING? THANKS
when you powder shrink the film wont "stick" to the glass. This makes it easy to over shrink the film. Use soap or dryer sheets as you heat the film it lays flat on the glass then "press" it to the glass and you almost cant overshrink it
Almost
      Contravision
    3. 29
    6. 3
    8. 3
    9. 4
