Dry ice dent removal
Guest Kokomo Tint & Dent
Any dent that you can fix with one of these shotty show off methods can be better fixed using much more practical methods. Like pushing the dent out by hand from the inside, using the right suction cup, or more commonly a glue puller or pick tools.
You may be able to start a car by hotwiring it, but its easier just to use the key.
Guest Tucker
Definitely use a hair dryer. If you heat the paint up too much it will discolor. The article on this dryicenetwork.com dry ice site says... heat it for about 10 minutes then place dry ice in the center of the dent. The dry ice will pull the dent right out.
Good luck!
Tucker
    2. 7
    6. 11
    7. 11
