Front doors laminated
Here at our shop we're used to getting fronts out very fast, until the lami ones came out. you can heat them but be very careful those thing are over 300 to replace and thats just the glass.
heres what we do. tint them like normal then heat the inside of the glass. dont set your gun too high and on low blast. just a little will tack it up faster because it will heat the adhesive before it heats the glass. we pull panels and rubbers here so there shgould be no reason to be heating out creases or dirt. but if you do need to heat these thing out it may work for that use as well.
good luck slappin papas
Click here to view the article
Guest BLACKOUT SoKal
:thumb sounds like common sense to me man, plus I hope those are LEGAL fronts that your shop busts out so quick down here in so cal :beer
    2. 7
    3. 7
    5. 7
    6. 0
    7. 11
    8. 11
