suntint Posted April 7, 2007 Report Share Posted April 7, 2007 Has anyone had problems installing 3M Dusted Crystal film where streaks show up? Did a job a couple of weeks ago and got a call not much after that there were streaks on some of the film. Went back and wiped everything down well - but they are calling me back so it must not have cleared up. At this point not even sure if the problem is on the outside of the film or something under the film. Link to comment Share on other sites More sharing options...
Guest mischief Posted April 7, 2007 Report Share Posted April 7, 2007 When we've had problems like that, they've always cleared up. Keep us posted. Link to comment Share on other sites More sharing options...
blade Posted April 7, 2007 Report Share Posted April 7, 2007 the streaking I've seen from our installs have always cleared up Link to comment Share on other sites More sharing options...
H.G. Posted April 9, 2007 Report Share Posted April 9, 2007 you have to clean the window after you tint it! just kikkin around, what solution are you using for install/ I've not had any problem with j&j but could be something in the lot no's. of the film??? adhesive overspray or something like that. Link to comment Share on other sites More sharing options...
Customtinting Posted June 6, 2007 Report Share Posted June 6, 2007 Have this in almost every install with this film. Clears up pretty quick. If it does'nt, contact the Manufacturer and have em check it out. Link to comment Share on other sites More sharing options...
Guest cgtinc Posted July 4, 2007 Report Share Posted July 4, 2007 The reason why you get streaks when you hang Dusted / Frosted Crystal is because it is actually a marking film for signage. I have hung a ton of them and it clears up within 6 hours of installation. Don't sweat it! Link to comment Share on other sites More sharing options...
suntint Posted July 5, 2007 Author Report Share Posted July 5, 2007 The reason why you get streaks when you hang Dusted / Frosted Crystal is because it is actually a marking film for signage. I have hung a ton of them and it clears up within 6 hours of installation. Don't sweat it! I know about those streaks - but that's not what this was. Marks were still there a couple of weeks later. Hard to describe, but almost looked like marks from someone touching the film with greasy fingers (but that's not what it actually was). Link to comment Share on other sites More sharing options...
Guest mhun9180 Posted July 6, 2007 Report Share Posted July 6, 2007 We had a big problem with it marking as you described. If you run your nail over it lightly it would leave a mark that won't disappear. Talk to the manufacturer because all the new batches we have coming through now are fine. Link to comment Share on other sites More sharing options...
