Toyota Aygo Back Window
Guest smcmahon
Guest smcmahon
anyone know how to do a toyota aygo back window? when heat shrinking it im left with loads of access film, ive tried lowering the anchor lines still no good some help from somone wud b much appreicated!!
1 month experience I would say you're not shrinking it enough. Not the easiest back window for a beginner. Where your attachments are on top you need to force the fingers away from the attachment then shrink them. Try to dry shrink until film is laying flat on top and bottom then do a final wet check and shrink what's needed to finish it out. Good luck dude...
Guest smcmahon
when I first seen it I didnt think it was hard but then started to do it then after the third time doing it I said PhU(|< this im going for a smoke!!! its not too bad round the top of the window its when you come to the bottom of the window cause theres a PhU(|< off curve in the middle of the window which fucks the thing up!!
    2. 7
    6. 11
    7. 11
