Alfa 159
Guest mhun9180
Guest mhun9180
I know it should be in the Auto section but I'm having no luck there. Has anyone done an Alfa 159? If so, how did you handle the sides? Pull panels, chock them, tuck them? Got one coming this weekend and need a heads up. Thanks in advance :dunno
Guest Rockabilly
There's four allen bolts in the door trim (you'll see where they are, easy to find - three bolts in the rear doors if I remember correctly) and then the panel easily pops off. With the front doors, you can unscrew the top allen bolt (the one behind the door handle) and pull the panel far enough away from the galss to remove the gasket (a hard plastic gasket) but its a real biatch to get back in (if the door panel is still on), so easier to pull the whole panel.
The felt/rubber trim around the door frame is a pain as well, but this is able to be removed. There is a wire that is hidden under the felt/rubber trim (I dont know what its for, maybe some sensor to tell the car if the window is up or not???) so just be careful of that wire.
Other than that, no major dramas.
    2. 4,168
      What did you tint today?
    3. 4
    4. 4
    5. 4
    6. 4
    8. 1
      Beginner Tinter
