08' Altima 2dr Coupe
Guest Thetintcenter
Guest maddtinter
I ususally vinyl the dots on most cars and on the Altima coupe my vinyl always dries uneven. I want to try and steel wool the dots but what grade steel wool should I get and what are the concerns I have heard in the past about dots rusting.
Dotted areas can rust,it is important to push out as much solution as possible.If possible heat with any source of heat(gun ,torch,drying lamps,sun).If you use steel wool 0000 super fine works good without scratching the glass.Make sure your steel wool has not been wet before because it will rust and then you can posssibly scratch the glass.If you use a coarser grade steel wool you will probably put fine scratches in the glass that may be noticeable when the sun hits the back glass at the right angle.
  • Replies 20
