zaino is here
Guest thetintshop
I have several questions.
1-why didn't you buy Z-1? (you really need it)
2-why did you buy Z-3? (unless you do alot of older cars, there's no use for it)
3-why didn't you buy Z-6?
4-do you know there is a wait of 24 hours between coats of Z-2 and Z-5?
Guest thetintshop
also, make sure you print out the tips section and do it exactly as they say to do it.
only use a small amount, it really does go a long way. the more you put on, the harder it is to get off, and the longer it takes to dry. and you're just wasting it.
Guest thetintshop
where are you located? cause you really don't need the ZFX unless you are in a cold climate. the only guys we sell that to are in minnisota, washington, ect.
Guest thetintshop
the Z-6 isn't the same as everybody else's stuff. other fast detailers will actually remove the zaino. they aren't compatable at all.
if you're in NC, you can probably use it and be ok. I apply mine in the winter when it's 50 degrees and don't need the ZFX. do it once without using it and see how long it takes to dry. the reason is that ZFX is expensive, and you have to use what you mix up.
