Top 3-5 window film manufacturers
I'm still fairly new so i haven't used a lot of film but i started with global and switched to Geoshield and really like that film, but I'm also thinking of trying union film because i have a discount with them. because i took the tint school online course -
Inquiring minds want know = other than price, why are you not happy with Global?? Your title asks about the top manufacturers. Well you are not happy with one of them and the only other two choices would be Llumar or 3M. Anything else you go with is still more than likely one of these 3. At least you better hope it is. -
I’ve been using global but not happy with them. Who should I go with -
My summa plotter wont connect to my computer even tho i have all plugs plugged in
I sometimes have problems with my plotter not cutting or even my program not detecting my plotter. When this happens, I go to system, device manager, Ports (Com & LPT) You should be able to see your plotter listed and the Com port it is associated with. Make sure your cutting program is pointing to the same device and Com port in the program's setup area. I usually end up sorting things out eventually. Other than this, I have no other advice as I'm just a novice computer tech 😬 -
Im having a lot of trouble with conecting my summa plotter to my laptop. I have multiple plugs going from my plotter to my laptop and everytime i open a sofware for ppf and tint templates it says no plotter detected even tho the software is telling me that is has cut the templates but the plotter didnt cut. If anyone could help that would amazing, ive been stuck on this for over 2 weeks and i cant find anything online -
Problems conecting my summa T1400 SL to my laptop
Windshield protective Film
Me too. Contact me for the address to send samples to. tinttech@optusnet.com.au -
Flat Glass Installer Pay
