Changing 'shaved' window to 'micro-edge'?
Guest Wade33Zo
Guest rcjello
44tools has a small tool that puts a 1/16th or and 1/8th inch gap on the top of the window if it's shaved. no need for a steady hand. its a small metal block with a groove and a place for a razor blade. all you do is slide the tool over the top and run it along the window.
Guest Key West
Is there any way to change a shaved window into a micro-edge window...meaning actual cutting the film down to a micro-edge? Thanks!
Why on earth would you do that? :evilgrin  There is either a gap, or no gap. The tool described from 44tools will leave about 1/16th of an inch gap, hardly a MICRO edge.
