Fiat Doblo Panorama
Guest shadowline
Havent tinted one but back glass looks easy, do it in place, why do you think you may have to remove it? Its got a big black surround looks pretty flat?
I do fiat doblo,but I wonder how do you do the glass from the door.and the glass from the back,we do it on the table because it;s more easy.you'll see when you get one in your workshop!
I´ve done about 5-6 doblo´s. U have to remove 4 side windows in order to do it correctly. All windows come out the same way - from inside u have to help with screwdriver and it should come out easily. To put it back u need some thin rope. I cant explain it in english but if u want, I can make some pics next time.
Not done a Doblo yet but have one coming soon.
I've done a Scudo with side windows which is similar. If you are talking about the sliding windows in the side doors I didn't think they came out.
I did the Scudo in place. A friend who did a Doblo got autoglass to take them out but then even they had a hard time getting them back in. These window frames are bonded with a stiff frame and are not like those with a rubber seal.
How exactly do you get them out?
Well, sliding windows are coming out like for example HIACE rear window. Then you have to take the rubber seal off and then you can separate two sliding windows. Other two windows (not sliding), with these you need to unscrew two screws and the third one, you have to drill it trough. Bad english but I hope U understood.
Guest naughtydog
From memory - the doblo sliding side windows are in plastic frames that you cant split - they looked plastic welded to me.
There may be a way but I couldn't work it out!
There is an area of the glass that seemed impossible to squegee.
Yes, you cant squege behind that button which opens the window. But u can split the frame for sure! Remove both ends of the frame and then stopper. Then one window comes out.
    d2iwindowfilm.com
      Independent Contractors needed for Security Film Project- Houston
    5. 4
      Mutoh Plotter
      Reveal Molding/Belt Moldings
    8. 4
