static
Guest exclusive1
Guest exclusive1
May be a left feild question but does anybody ever have static problems with ther film handler? I have been getting shocked so damn bad latlely I can see the spark. I have it on a fiberglass ladder, do I need to have it grounded?
Guest haroldshouseoftint
:thumb I don't use a film handler, but in the spring time, I know we get alot of static in the air here, you get shocked alot getting in and out of your car
you don't need to ground it ... if you don't mind the shock :thumb:spit:spit
I ground if I'm pulling a lot of security film cause it feels like a 110 jolt , if you're only pulling a few pieces , when you lift the cutting bar to pull, just keep one hand on it while pulling . but grounding is the best :thumb
I get it all the time - specially w/ safety film - touch ur channel or metal max handle to it 1st - watch the spark
or use a metal ladder - it works
