I need some quick help
Guest Nainoa
Guest Nainoa
I have a 94 ford ranger in the shop...my plotter doesnt have this vehicle in the system....I already did the two doors....the back is a 4 piece slider window and I cant get the cut close enough to the rubbers....any help please
Guest zolar
I cut out a pattern from clear liner on the inside
and can usually get it very close
you can trim a little of the rubber off
and cut the pattern a teeny bit bigger
:cool:olfa
Guest Nainoa
excuse me I meant the round corner parts ...the straight cuts are fine.....
Guest thatsnappyguy
perfect example of relying on a machine to do all your wrok. sorry, but its true. I wonder how all them "ltinters" at the dealerships would act if the all the plotters got a virus at the same time...hmmmmmm :olfa
Guest Texstar
I do it like the rest of the actual people trying to help
Heat the rubber up a little on the inside and it will trim easier
Good luck
Guest krivera418
perfect example of relying on a machine to do all your wrok. sorry, but its true. I wonder how all them "ltinters" at the dealerships would act if the all the plotters got a virus at the same time...hmmmmmm :spit
:spit my thoughts exactly
