hoosierwindowtek Posted March 7, 2008 Report Share Posted March 7, 2008 Does anybody have any good tricks for dealing with those? I use the trick of spraying really soapy water on the edges of the film, and into the side gaskets of the windows, but they are possibly worse than the early 90's Accords. Link to comment Share on other sites More sharing options...
Guest willie Posted March 7, 2008 Report Share Posted March 7, 2008 Does anybody have any good tricks for dealing with those?I use the trick of spraying really soapy water on the edges of the film, and into the side gaskets of the windows, but they are possibly worse than the early 90's Accords. Hoosier, I do a few of those a month. I tape the seals and do the same soapy water trick. Link to comment Share on other sites More sharing options...
Guest Crackz Posted March 7, 2008 Report Share Posted March 7, 2008 I havent had the chance to do one yet but looking forward to it now they you say it was tuff Link to comment Share on other sites More sharing options...
hoosierwindowtek Posted March 7, 2008 Author Report Share Posted March 7, 2008 Does anybody have any good tricks for dealing with those?I use the trick of spraying really soapy water on the edges of the film, and into the side gaskets of the windows, but they are possibly worse than the early 90's Accords. Hoosier, I do a few of those a month. I tape the seals and do the same soapy water trick. The new ones have smooth rubber seals, so there's no fuzzies to tape. Do you still tape them to help the film slip behind? I'd be afraid that'd just make the gap even tighter Link to comment Share on other sites More sharing options...
Guest willie Posted March 7, 2008 Report Share Posted March 7, 2008 Does anybody have any good tricks for dealing with those?I use the trick of spraying really soapy water on the edges of the film, and into the side gaskets of the windows, but they are possibly worse than the early 90's Accords. Hoosier, I do a few of those a month. I tape the seals and do the same soapy water trick. The new ones have smooth rubber seals, so there's no fuzzies to tape. Do you still tape them to help the film slip behind? I'd be afraid that'd just make the gap even tighter I tape everything that I cant remove. And I used a taped up old drivers license or my ez reach on those :inot Link to comment Share on other sites More sharing options...
Mdog Posted March 7, 2008 Report Share Posted March 7, 2008 Is this a new body style? If so I havent tinted one yet. Link to comment Share on other sites More sharing options...
hoosierwindowtek Posted March 7, 2008 Author Report Share Posted March 7, 2008 Yes, I think it's completely new. Link to comment Share on other sites More sharing options...
b_faulk75 Posted March 11, 2008 Report Share Posted March 11, 2008 I have a 2 door version in my shop now, first one and the seals are TIGHT AS HELL, I had to do both fronts 2 times before I got the film to slide in the way I wanted, I even DOUBLED the slip solution and still had problems, these seals will go down as one of the tightest I have had yet... and good luck for tuckers cause I even removed the lower seal and they were still a bitch... Hope someone figures out a trick... Link to comment Share on other sites More sharing options...
Guest naughtydog Posted March 11, 2008 Report Share Posted March 11, 2008 Yep - they are tight MOFO's Link to comment Share on other sites More sharing options...
Guest Dentless Dave Posted March 19, 2008 Report Share Posted March 19, 2008 Just pull the door panels back a little and pull the gasket out. DONE! You may have to lube the gasket up a little with water to get them to slide in, but it makes the 08's so friggen easy! I work for a Ford Dealership and I've tinted over 100 of these damn things! dave. Link to comment Share on other sites More sharing options...
