Visor Bow
Its basically an aluminum strip with a chain attached. It enables you to cut a perfect visor strip off the car.
How to build:
1)Select an aluminum strip about the same width and thickness of an aluminum yard- or meter- stick. You’ll want its length to be sufficient to cut the longest windshield strip you’ll be likely to encounter.
2) Obtain a length of ¼-inch diameter link chain, a few inches longer than the aluminum strip.
3) Drill a1/8-inch diameter hole at each end, in the center & ¾” from each end. Use a hacksaw to cut in slits from the end to the holes, wide enough for a link in the chain to fit sideways into the slots.
4) Insert one end of the chain (a link or two in), then use a pop-rivet or screw to lock the chain into the slot. You now can adjust the arch of the “bow” using the chain inserted (at various lengths) into the slot at the other end.
5) Clean the aluminum strip thoroughly before wrapping a colored vinyl tape completely and evenly around its bottom edge. This will provide excellent grip during the cutting operation, using this bowed aluminum strip as your blade guide.
Guest irishhanks2
How to build:
hey thats sound like a lot of work when you can use the top of the windshild and get the same affect :dunno
Guest General Sun Shield
How to build:
yeh.thats what I do also. :poke
I dont use it, I just saw it on LLumarTech.com and wondered if anyone ever built one of these. I figured you could also use it to threaten any unhappy customers with it. Can you imagine walking around with this on your shoulder...lol You wont have any lippy customers...lol
    valiant
      Best ceramic film
    2. 9
    3. 9
      Best ceramic film
      Unknown Marks On Windows
    5. 7
    6. 7
    7. 9
      Best ceramic film
    8. 7
    9. 7
    10. 7
