Vinyl on wood
Guest type-xdesigns
Guest windowpimp
we regularly print 4x8 on our versacam printer/cutter,, its 54" so 4 x8 can be printed in one piece... regularly we install on crezone, which is a plywood with a good one or two sides... the good surface is a hard paper coating,, we dont paint the surface, just apply....direct...
Guest TangentSigns
I would have uesd 3mm PVC board, when bought in 4x8 not to expensive - light weight everything sticks to it. You can make a nice print and Run it through a lamnator. Looks great do it all the time as long as you use your plywood for a backer.
