Headlight resin as a matrix fix
Ok I usually glue matrix on rear screens.......
Before I have a go with headlight resin, is it hard to get off if the car comes back for a re-do? And if your applying it in an area of martix where there are defoggers or antenna could it get stuffed removing it?
Guest Thetintcenter
The resin will dry to lookand feel like glass. If you have to do a re-tint, the resin will stay on the matrix. So there really is no reason to scrape the resin off. It also will not interfere with antenna reception. If you need to do a re-tint it will be because of contamination...not the Resin. Hope this helps. :twocents
