I have Air80 on FWS, 35 on 4 doors. I am happy rejecting some solar energy and having no visibility issues at night. The 15% you have will make the FWS look darker I assume. During the day it would not be a big difference, only at night. I know a FWS ticket is $$, I didn't want to give a bored cop an excuse to pull me over. Or have the chance to notice the FWS while being pulled over for something else. The less I talk to cops the better. -
12
12
12
Geoshield vs Maxpro
Global HP and Ceramic. Using it full time for seven years and not a single failure that wasn't my fault.
