cdf PEELING CORNER
Guest RCOOTE
  • Replies 25
Get a bottle of clear nail polish. Dab the corner with a drop, push the film down and it will draw it in as it wants to lift. Let it set for a sec, push and hold. After it sets, it will hold a look fine. Be sure to wipe the excess off the exterior of the film. This issue can also happen if you bite the film to release the liner. Sometimes it will cause this. The nail polish trick I have used for year and it works great.
Guest willie
Isnt that a tip :dunno
Guest RCOOTE
GREAT TIP.... I will now add this to my tool box.. :dunno:lol2
Guest tintgod
The latest tech bulletin from Llumar says to make sure your application fluid is slightly acidic to activate CDF adhesive... They say that if it's not, then the adhesive will not bond quickly.
so...you can put a couple drops of lemon juice in your sprayer and you will be fine.? :thumb
if never experienced peeling on cdf films other than llumar. period :):)
so...you can put a couple drops of lemon juice in your sprayer and you will be fine.? :)
x-100 is what you're supposed to use, but seriously I've wondered if you couldn't use lemon juice or citric acid powder or something. :)
if never experienced peeling on cdf films other than llumar. period :thumb:thumb
I was told a couple years ago that CP (or whomever makes their films) had changed the adhesive... I don't know how true it was, (that came from another film company) but all the sudden I was having problems with lulu's films. So I started using the X100 and everything was fine after that.
-R
    2. 7
    6. 11
    7. 11
