almunny2007 Posted May 18, 2008 Report Share Posted May 18, 2008 I'm having a hard time getting this back window right. I use the mdog soap method and I get vertical creases all throughout the window. They are mostly at the top of the window. I use suntek film and have'nt had any trouble with any other models I've done. Is there a special way to shrink this back window? I know the defroster lines are thick as hell, but my problem is the shrink itself. I've moved the anchor low and high, but I still can't seem to get it to shrink right. Please help me out Link to comment Share on other sites More sharing options...
Guest Crackz Posted May 18, 2008 Report Share Posted May 18, 2008 dry shrink with powder do the bottom as normal if you still have problems with the top try the pull method Link to comment Share on other sites More sharing options...
almunny2007 Posted May 19, 2008 Author Report Share Posted May 19, 2008 Thanks man. I'll give it a try Link to comment Share on other sites More sharing options...
smookee408@yahoo.com Posted August 4, 2008 Report Share Posted August 4, 2008 dry shrink with powder do the bottom as normal if you still have problems with the top try the pull method The pull method is not to be confused with the pull out method thats how I ended up married and with a kid. Link to comment Share on other sites More sharing options...
Guest jamm4 Posted April 20, 2009 Report Share Posted April 20, 2009 dry shrink with powder do the bottom as normal if you still have problems with the top try the pull method not to be confused with the pull out method thats how I ended up married and with a kid. LMAO!!!!! Link to comment Share on other sites More sharing options...
