Dot matrix
Good lord this Ford Fusion I tinted has matrix from hell. Glued it and it came back with one little spot looking off, so I removed it and vinyled it. Now the vinyl isnt looking right either. Same crap, damn this matrix is thick.
any suggestions guys? I have never had a comeback 2x for matrix and once is very rare, after the vinyl wont work what else is there to do? Other than a brick to the window...
We had a car ike that before... seems like nothing will work....
Sounds like you are on the right track... scuff and re-apply a good quality vinyl.... like a Avery A9 or Oracal 851 series... If that don't work... the custy should understand it is now out of your control....
Guest Thetintcenter
Use the Resin! Check Tip of The Week
Okay, well the custy was bein too picky it was a normal install. Anyhow I did vinyl over the back on the outside... although I really think the dude just wanted vinyl on the outside for some reason... sounds like he will be doing the visor like that too.
