Guest cartek Posted May 22, 2008 Report Share Posted May 22, 2008 what can I use in the meantime? any input? Link to comment Share on other sites More sharing options...
smookee408@yahoo.com Posted May 22, 2008 Report Share Posted May 22, 2008 use a slammer or a slim bigfoot. or just remove the decklid. You can tint like the $99 dollar hacks and cut around the brakelight Link to comment Share on other sites More sharing options...
Guest cartek Posted May 22, 2008 Report Share Posted May 22, 2008 use a slammer or a slim bigfoot. or just remove the decklid. You can tint like the $99 dollar hacks and cut around the brakelight I used to do that Link to comment Share on other sites More sharing options...
Guest olletsoc Posted May 22, 2008 Report Share Posted May 22, 2008 first thing you should do is keep a back up on hand. I have 2-4 of every tool I use daily Link to comment Share on other sites More sharing options...
Mdog Posted May 22, 2008 Report Share Posted May 22, 2008 For years before there was a bulldozer I used a clipboard or a 3 ring binder cover. Some binder covers are stiffer than others and they work very well because they have that vinyl covering on them making for a good squeegeeing effect. Link to comment Share on other sites More sharing options...
Graviteesfx Posted May 22, 2008 Report Share Posted May 22, 2008 cut a piece of your tint box to the desired shape and cover the edges with masking tape. It's ghetto but it can get you out of a bad spot Link to comment Share on other sites More sharing options...
Guest djtekk707 Posted May 22, 2008 Report Share Posted May 22, 2008 Yea just use a stiff 3ring binder cover and hit urself for leaving your men behind Link to comment Share on other sites More sharing options...
TINTDESIGNZ Posted May 22, 2008 Report Share Posted May 22, 2008 yep-that sucks! I left mine in the kitchen once...was using it to flip burgers! Link to comment Share on other sites More sharing options...
Guest Tint Technology Posted May 22, 2008 Report Share Posted May 22, 2008 yep-that sucks! I left mine in the kitchen once...was using it to flip burgers! Link to comment Share on other sites More sharing options...
Guest De4thMet4LKing00 Posted May 22, 2008 Report Share Posted May 22, 2008 use a slammer or a slim bigfoot. or just remove the decklid. You can tint like the $99 dollar hacks and cut around the brakelight So, if you cut out the brake light, you're a hack?? Link to comment Share on other sites More sharing options...
